Sponsored by:
Sponsored by: DashLynx
Loose camshaft adjustment outlet side
Old 02-17-2016, 07:05 PM
hyancey's Avatar
Default Loose camshaft adjustment outlet side
Just purchased a 2004 s60 2.5t with 65k miles on it. After looking around the forum a bit, I decided to go to the heralded Volvo mechanic at Euro Auto Plex "John" in Chicago to get a timing belt kit installed.
After taking a look around, he said the previous owner had put sub par oil in the engine resulting in a loosening of the "V. Valve actuator" (part # 9497786). I had noticed the timing was a little off, but attributed that to the timing kit needing replacement.
He flushed the engine, and put syntehtic oil in, but said the part needed to be replaced on a 6 month timeline.
That being said, is this worth getting a new one? I have no tools so I would not be able to do myself, but are there any alternatives? Should I be concerned with getting it fixed this early? Also, is it completely necessary to buy the part from the dealer, or would an OEM part do.
Thanks!
Old 03-11-2016, 12:20 AM
Greg1234's Avatar
For that questions you better talk to volvo tech I did ask volvo tech for vvt hubs you need special tool if is solenoid no tools . If you in Chicago you can email private volvo mechanic Chicago at volvochicago@live.com and I know he is cheaper and better then europlex
suhua4
04-17-2021 09:13 AM
unuruu_amina
12-05-2011 11:06 PM
s40volvo
09-10-2011 08:10 AM
griffinlinks
10-11-2010 08:28 PM
nextproject
11-16-2009 07:04 PM
Quick Reply: Loose camshaft adjustment outlet side
