Sponsored by:
Sponsored by: DashLynx
View Poll Results: A poll
Drain and Fill three time
71.43%
Fluid Flush
28.57%
Voters: 7. You may not vote on this poll
Drain and Fill x3 or Flush?
Old 06-16-2007, 01:09 PM
piercebrew's Avatar
Default Drain and Fill x3 or Flush?
I have a 2001 2.4T, with 105k, I'm trying to decide if I'll drain and fill or flush the transmissio fluid. Please your feedback if you have actually done either.
Thanks
Old 06-20-2007, 10:31 AM
piercebrew's Avatar
Default RE: Drain and Fill x3 or Flush?
How does no one have any input about this?
Old 06-22-2007, 07:24 AM
FredMc's Avatar
This is not a large forum of active users.
It's preference. I would first insure that the correct message is going out about the correct fluid to use. Only Mobil 3309 should be used. That's a slam dunk. Someone on here is using Amsoil (which will work but is not approved), and others (minority) are uneducated about what Volvo sells since they think (incorrectly) that it is differenct than Mobil 3309 (it's the same people).
I drain and fill because I change my own motor oil too. All I have to do is loosen another drain plug fitting. Almost every four months I add new synthetic motor oil (currently Pennzoil Plat), and then I also add 3.5 quarts of 3309. I have one more drain and fill to do to consume my 3309. Then I am good for quite sometime after that (probably 2 years).
Trans shifts just fine thankyou.
NCS60
04-09-2022 11:54 AM
zpmada
09-30-2012 02:14 PM
jasonl
01-28-2011 11:49 AM
crodri21
10-23-2009 09:48 PM
dads 740 turbo
11-13-2008 12:14 AM
Quick Reply: Drain and Fill x3 or Flush?
