front engine noise after coolant drain and fill
Old Sep 29, 2012 | 07:14 PM
zpmada's Avatar
Default front engine noise after coolant drain and fill
I'm having an odd problem. I just drained and filled the coolant system after replacing the radiator hoses. Now I have a mechanical sound that happens when I gently rev the engine. It almost sounds like a fan scrapping on something, but that can't be the case because the fan is electric and doesn't depend on engine speed. Could an air pocket in the water pump cause this sound? How could I solve it? If the pump isn't pumping coolant how do I burp the system and will a dry water pump get damaged? Some coolant got splashed near the belt area as I was refilling and I'm not sure if that damaged anything. Any ideas? It is definitely coming from the serpentine belt area.
Old Sep 29, 2012 | 08:15 PM
Ozark Lee's Avatar
The system should burp itself. If the thermostat has been replaced it likely doesn't have a jiggle valve to let the air bypass a closed thermostat. In that case you will need to let the car warm up to get the air to bleed out.
I always drill a 1/16" hole in a new thermostat just for that reason.
...Lee
Old Sep 29, 2012 | 08:27 PM
Brick850's Avatar
I'd always wondered what the little hole was there for in the thermostat LOL
Old Sep 29, 2012 | 11:29 PM
Drive it and see what happens.
Old Sep 30, 2012 | 02:14 PM
After driving it a bit did the coolant reservoir level drop a little ??
akabond
Jan 13, 2014 12:52 AM
jasonl
Jan 28, 2011 11:49 AM
crodri21
Oct 23, 2009 09:48 PM
dads 740 turbo
Nov 13, 2008 12:14 AM
piercebrew
Jun 22, 2007 07:24 AM
