Sponsored by:
Sponsored by: DashLynx
2006 S60 2.5T - Steering rack binding?.
Old 02-07-2023, 02:38 PM
Bessarion's Avatar
Default 2006 S60 2.5T - Steering rack binding?.
So, had a chat with my mechanic about the power steering seemingly binding every 1/4 turn or being very heavy after staring the car (new PWR steering pump. It turns out that power steering hoses do NOT leak. He believes the gear on the power steering rack is binding, i.e. need new rack. That's $300 for remanned rack and $1,100 in labor. There is no other symptom of a bad rack (no leaks or free play, no noises). Has anybody else have a similar symptoms? is it possible it's a lower U-joint simply seizing?
UPDATE!!!! It does seem it is the u-joint seizing. The hard "spots" go away after u-joint was lubricated (saved me $1,200). I will continue the u-joint maintenance until we replace the lower steering shaft ($300). The lesson - do NOT replace steering rack until you service the u-joint, and it may take a few days to actually work!!!
Old 02-07-2023, 06:37 PM
ssicarman's Avatar
I would certainly check the steering shaft u joint for seizing. It could explain the 1/4 turn binding. The heavy feeling maybe not so much.
Old 02-07-2023, 07:33 PM
Bessarion's Avatar
That was my opinion. I will also flush the system with new oil.
Bessarion
01-31-2023 10:46 AM
M4tt79
Volvo C30
06-09-2021 01:52 AM
codgamer10149
09-13-2018 01:20 PM
Gates47
06-28-2016 01:56 PM
Volvo70
03-18-2007 03:22 PM
Quick Reply: 2006 S60 2.5T - Steering rack binding?.
