Stiff Power Steering
Old Sep 4, 2018 | 07:05 PM
codgamer10149's Avatar
Default Stiff Power Steering
Hello all. I am the owner of a 2006 Volvo S60 2.5T. I am having some issues with my power steering system. I would like to get an opinion on what the issue could be. I've flushed the power steering system and I've replaced the power steering pump with a working used pump from another car that is exactly the same as mine. I also used CHF 202 as the power steering fluid. It would be greatly appreciated if I could get some advice on the issue. Thanks.
Old Sep 5, 2018 | 07:18 AM
ES6T's Avatar
The lower steering shaft u-joint could be binding.
Old Sep 12, 2018 | 12:54 PM
pierremcalpine's Avatar
I've got the same problem. I have replaced the pump, flushed the fluid, replaced the u-joint AND jacked up tire pressure to 40psi (just to see what impact it had). Still pretty stiff at low speeds to the point where my wife says she doesn't want to drive it anymore. Rack doesn't leak though. Is it possible for rack to be shot even if no leak is present?
Old Sep 12, 2018 | 08:19 PM
tony1963's Avatar
This is almost always a failed rack and pinion unit. While it is rare, it does happen. We had one a couple of years ago that other than the stiff steering, the car was well maintained. We concluded that it was traded in and we bought it for a song with a bad rack.
We sourced a reman rack and dumped all of the oil fluid, flushing the lines and replacing the reservoir and cap. Installed the new rack, used correct fluid and the car drove like a dream. I believe that we spent about $500 in parts.
Old Sep 13, 2018 | 12:07 PM
Thank you, Tony. Would you take the risk of going with a wreckyard rack or would you suggest reman?
Old Sep 13, 2018 | 01:20 PM
tony1963's Avatar
I prefer the convenience of reman parts.
rphud
Jan 8, 2013 01:10 PM
91shelby
Oct 3, 2012 01:02 PM
chadman551
Jun 23, 2010 09:30 PM
borrone821
Dec 9, 2009 06:31 PM
cbassj8
Aug 19, 2008 07:15 PM
