Grinding Noise
Old 10-29-2008, 05:11 PM
Woodlax's Avatar
Default Grinding Noise
I just had all 4 rotors and brake pads replaced on my 1998 S70and drove about 200 miles on them, theymake a little noise butI don't really care. Recently though I've startedhearing a really loud grinding noise that sounds like its coming from under my car somewherebehind the passenger seat. I checked under my car... nothing is hanging or even looks like its loose. The sound I'm hearing is extremely loud and sounds like the car is actually dragging on the ground. Seems to happen randomly while driving,even when I'm not using the brakes. Anyone ever run into this before?
Old 10-30-2008, 07:56 AM
Default RE: Grinding Noise
That is strange. I would have the suspension checked.
Old 10-30-2008, 08:46 AM
S70GLT's Avatar
On my 850 I had the heat shield come loose once, that rattled around just about like you're describing, I'd assume they'd be in the same spot on the S70.
Old 10-31-2008, 08:06 PM
1998S70T5SE's Avatar
wheel bearing would be a good start, in my opinion.
flyingcurtains
12-03-2007 01:43 PM
gooproduct
10-26-2007 07:29 PM
stu_cole
09-21-2007 06:22 PM
jabbo
08-01-2007 07:47 PM
rantiddlybobo
04-11-2004 12:47 PM
Quick Reply: Grinding Noise
