creaking climate control noise at temp
1998 S70 T5 with automatic climate control. When the climate control gets the cabin to the set temperature, a rhythmic creaking noise can be heard inside the dash behind the center vents. If I set the climate control significantly warmer or colder, the noise goes away. My best guess is that the noisy part is trying to maintain temp rather than heat or cool the cabin. I took the glove box out and found the source of the noise. As near as I can tell, it is Volvo part number 9132629. I've seen it called many names on the internet, but it's obviously a blend motor that helps regulate cabin temperature by dicking with the vents. Here is the part that is making the noise.
So I've got three questions:
1. Is this part 9132629?
2. Is there a trick to getting it out of there without taking more of the dash down?
2. Is it more likely that the motor is bad or that the vent baffle is jacked up?
I do not see an easy way to get into the ductwork and see if the mechanical parts are obstructed or need clean/lube.
Thanks in advance.
Thanks in advance.
spankey
10-08-2009 11:27 AM
Steamroll9
05-10-2005 08:41 PM
