Noise after cv axle replacement
Old 03-01-2016, 04:58 PM
Folkswaggin's Avatar
Default Noise after cv axle replacement
230,000 miles. Replaced driver's side CV axle today (boot was torn & clicking sound). Used Advance Auto Carquest axle. After putting everything back I hear metal on metal sounding squeal when driving at most any speed. I removed and reinstalled & rechecked torque specs, same problem.
I replaced passenger side cv axle maybe 3 months ago and had no problems there. I don't have any idea where to start. Bad axle? Should I have greased splines in bearing? Bearing? Any advice?
Father of 3, touring musician, very much on budget, hobbyist of all, not terribly experienced nor dense. Hopefully.....
Old 03-01-2016, 05:52 PM
did you look at the brake splash guard? Wondering if it got damaged during your R+R and is now rubbing on the wheel or disk.
Old 03-01-2016, 07:01 PM
A very sensible response, the noise sounds as if it very well could be the splash guard. Thin metal scraping sound. I did check the splash guard but tomorrow morning I'll remove the tire again and look in more detail. Thanks.
Old 03-02-2016, 09:14 AM
Sure enough bottom of splash guard was rubbing against rotor. A little nudge helps and I thank you.
On to other things....
Mixre
12-26-2016 12:10 AM
hazoomeh
09-02-2014 12:11 PM
kenstanza1970
06-20-2010 12:37 PM
JP
10-18-2009 11:10 AM
mafiosoroso
10-22-2007 09:20 PM
Quick Reply: Noise after cv axle replacement
