SRS Light
Old 09-12-2015, 03:21 PM
HesplerS70's Avatar
Default SRS Light
Have a 99 S70T5. The SRS light is on. Got estimate from dealer for $1200. 3 codes, they could not clear them. Any ideas or recommendations to get it off. They said most likely need a new module.
Old 09-15-2015, 04:37 PM
not sure what you mean by saying they could not clear the codes. If the codes are being thrown by a faulty air bag unit, then that needs to be replaced. Before you replace the air bag unit, the shop should check for any other wiring issues - ie a connector under the seat, wiring harness issues. Were they able to tell you which airbag is throwing the fault or if its one of the noise sensors?
Old 09-17-2015, 10:28 AM
bmdubya1198's Avatar
Did they tell you the codes and what they mean? That would probably help. I don't know much about airbags, but a module is NOT $1,200.
lister99
12-28-2012 10:46 PM
Danigirl
02-22-2012 01:36 PM
guptash
11-19-2011 04:17 PM
Sparky4688
09-26-2009 06:22 AM
strauss8
04-23-2004 07:42 PM
Quick Reply: SRS Light
