2000 S 80 transmission starting to slip should I change fluid?
Old 02-28-2015, 10:09 AM
mojobaby27's Avatar
Default 2000 S 80 transmission starting to slip should I change fluid?
2000 S 8o 2.9 auto transmission. Starting to slip has 160,000 miles. Should I change fluid? If so what type and how much? Some people recommend flushing some people just drain the pan and do three of four quarts a time. Thanks
Was thinking Mobil ATF 3309 Transmission Fluid - 4 Quart kit .
Old 03-03-2015, 08:41 PM
difflock54's Avatar
'Drain and fill' is the safest and probably the easiest start point in solving the issue.
Many posts exist on forums that advise not to do a flush at all.
What is the color of the ATF on the dipstick and is the fluid level correct?
Old 03-03-2015, 09:18 PM
difflock54's Avatar
http://www.matthewsvolvosite.com/vol...missions-guide
Do you have a 4 speed transmission? AW50-42LE.
JWS 3309 is not suitable for some 4 speeds but is correct for 5 speeds.
See the link above and also check your manual for recommended ATF type.
i.e. Dex III ?
Old 03-09-2015, 09:40 AM
mojobaby27's Avatar
Default The fluid is reddish /brownish
paper Towel looks reddish brownish, fluid level is A little over recommended hot level, probably A half a quart over.
Transmission type is four speed. FWD. AW5.
I FOUND ATF TYPE TLS ON THE FCP SITE , BY IDEMITSU SAYS IT IS A DIRECT OEM FOR TYPE Volvo gearbox oil 1161540, which is the Volvo part number recommended. seems to be a reasonable price.
Stratoblaster
01-18-2023 10:26 AM
lovmyvolvo
Forum Issues
02-14-2015 09:49 AM
slipinxc70
2001-2013 model year XC70
05-09-2013 08:55 PM
integrity23
02-09-2012 01:50 AM
mason_200
05-17-2010 09:48 AM
Quick Reply: 2000 S 80 transmission starting to slip should I change fluid?
