Should I change my Transmission Fluid
Old May 13, 2010 | 03:44 PM
mason_200's Avatar
Default Should I change my Transmission Fluid
I have a question about my Transmission Fluid. My V70 XC has about 110,000 miles on it. The Transmission Fluid is dark. When I went to my Volvo Technician, he said I should not change the fluid as its a 50/50 chance it could cause problems. The transmission is fine, its just the color of the fluid I am concerned about.
What do you guy's think?
Old May 16, 2010 | 04:11 PM
VTBricked's Avatar
Transmission fluid should be changed at least every 50k miles. Get a flush kit with instructions if you're not sure/confident about the job.
Old May 17, 2010 | 09:48 AM
Miasvolvo's Avatar
Your transmission fluid should be a red color. You should absolutely change your transmission fluid like BTBricked said. If you feel uncofortable doing it yourself, I would try to find a garage that has a machine that does it for you. Iam uncertain of pricing, it will take half an hour at the most.
Stratoblaster
Sep 2, 2024 11:18 AM
mojobaby27
Mar 9, 2015 09:40 AM
AustinPower
Nov 11, 2008 07:43 AM
novablue69
May 12, 2006 09:05 PM
