S80 High beam not working
Old 05-26-2016, 09:27 AM
philk's Avatar
Default S80 High beam not working
Hi
Ive recently bought a 2005 S80 and i have an issue with the headlight full beam not working ---- and no, this isnt the usual problem !! I have the lights on 'full on'
I have no flash or high beam, the bulbs look ok.
I suspected fuses or relays but I cant seem to find them to check - any suggestions ?
I have removed the stalk to see if there were any visible signs of damage and there doesnt seem to be.
If anyone can shed any 'light' on this it would be very greatfully received.
Many Thanks
Phil
Old 05-26-2016, 10:17 AM
fuses are in the panel under the steering wheel (22/23). Check connections/sockets, relays.
Old 05-26-2016, 11:09 AM
philk's Avatar
Hi. Thanks for that
Checked everything i can see and all looks good - Im just trying to avoid main dealer costs but it looks like that may be where im heading
Old 05-26-2016, 05:04 PM
possible causes are 1) stalk switch 2) relays 3) connector into each bulb. did you also try swapping out the bulbs? I've had bulbs be bad that looked ok to the naked eye...
Old 10-21-2020, 02:21 PM
Springmeadow's Avatar
Hi Same problem 2007 S80 D5. I know it’s a while ago you posted but could be useful to someone else. Things I done.
Checked fuses
Turned light switch to Headlights
Replaced indicator stock
Noticed fog lights were not working either.
Noticed light switch not lighting up
Replaced Light switch. Bingo sorted it. Hope this helps someone
Volvo_Neps
1998-2000 model year V70
10-07-2013 10:28 PM
S80inVA
01-24-2011 08:58 PM
Volvoguy505
09-11-2010 05:53 PM
EnzoRacing
12-06-2009 11:06 AM
Quick Reply: S80 High beam not working
