problem starting up the car when the engine cold
Old 08-11-2015, 01:37 PM
bksmartit's Avatar
Default problem starting up the car when the engine cold
I have 2001 Volvo V40 1.9T and I noticed when the engine is cold it takes longer to start the car but when the engine is worm I have no problem to start quickly. I am not sure what it could be but I feel like there is no fuel and it takes a 10 seconds to start the engine. I have new battery, I have fuel in the car.
Does any one know what it could be?
Thank you
Old 08-11-2015, 02:23 PM
ES6T's Avatar
You need a fuel pressure regulator. There should be plenty of info around here about it.
Old 08-12-2015, 12:48 PM
bksmartit's Avatar
Hey ES6T, thank you for sharing this information!
I looked on this forum about a fuel pressure regulator as you suggested and it seems this is a problem I have... I am looking forward to purchase this part and replace it.
I will post the result.
Old 08-25-2015, 09:25 AM
bksmartit's Avatar
I purchased a fuel pressure regulator on eBay for $120. I installed new fuel pressure regulator on Saturday and viola! It fix my problem.
Many thanks to ES6T
Old 02-10-2016, 05:03 PM
WildFish's Avatar
Default Vacuum Leaks
Check for vacuum leaks before you buy the regulator.
Had the same problem, and once the vacuum leaks were fixed it started right up.
jbasilone
03-15-2014 10:59 AM
RStrohl
1998-2000 model year V70
02-12-2014 12:18 PM
matt01
01-27-2012 03:48 PM
seholber
08-19-2011 04:48 PM
mick1275
05-04-2007 08:17 PM
Quick Reply: problem starting up the car when the engine cold
