Engine: T5: - Problem With Boost /poor Cold Starting
Old May 4, 2007 | 08:17 PM
mick1275's Avatar
Default Engine: T5: - Problem With Boost /poor Cold Starting
C70 T5 2001 Had this car now 14 months problems started while driving to work 3rd gear 40mph i put toe down alittle and bang it back fired twice no more boost. Volvo diagnosed a bad MAF replaced it and still it wont boost it hits the 3/4000 rpm you hear the turbo whistling away but no power i changed the diaphram in actuator the other day and still same if i slightly adjust the rod its worst . A flat spot has occured on low rpm at stand still just blipping throttle and every morning i start her up its bad ,popping and farting trying to cut out this contiues for 3/4 mins with alittle blue smoke and i mean only a lttle few puffs but as soon as it clears she runs fine.. .I have a friend whos a volvo tech but hes ****e because the volvo laptop is not showing any faults at all he doesnt know what problem is . I have a new ETM on, MAF sensor just replaced, inlet manifold gasket, injector seals replaced, new spark plugs, new pipe clips and all checked for splits , STILL NO BOOOOOST .When i did the work on the engine eg:gaskets and injector seals i had the battery disconnected for around 24hrs so i presume it reset the ecu ?, It ran like a brand new c70 it was buzzing then after about 40 miles these problems have reoccured still no engine warning lights
there are my plugs in 1 week after cleaning plugs tell you alot about your engines condition the red core and white tip isnt good news i think my car is running too hot in some way.but my temp is at normal half way up on the temp gauge If anyone has idears , before i have to get a bank loan for the cost at volvo main dealers it would be goooooood !
[IMG]local://upfiles/9394/93413E24A74E4B2F9DC1BF2912420A7D.jpg[/IMG]
[IMG]local://upfiles/9394/525AD3C22AF24951B262FAB72595532F.jpg[/IMG]
bksmartit
Feb 10, 2016 05:03 PM
ms000
Jan 2, 2015 11:15 AM
blackguy_with_volvo
Jan 10, 2014 11:12 AM
endneu913
Mar 28, 2010 11:41 PM
browntrout
Jul 21, 2006 12:08 AM
