2002 V70 T5 Clock Problem, Advances Continuously
My 2002 V70 T5's clock in the instrument cluster will advance continuously as if a ghost is trying to set it at high speed. This is happening most times after start. If I start the car and it works normally and I try to set the clock I am able to sometimes, but other times it starts to race again. Also, while the clock is racing I am unable to stop it with the setting ****. The trip odometer will not respond to me trying to reset or change from 1 to 2 while the clock is racing.
Any guesses?
Thanks in advance.
Any guesses?
Thanks in advance.
DIM replaced - clock works!
I eventually had to replace a flaky Driver Information Module or Instrument Cluster - it started with the clock then intermittent instruments etc - sounds like the 2002 and 2003 models were susceptible. Sounds like the circuit boards would have issues (heat, solder, etc). A company in Canada called Xemodex can send a refurbished guaranteed for life module for under $500. Definitely better than the dealer's $1,400. I've read where others had success reflowing solder on the circuit boards but that was beyond my comfort for such small chips.
bcolins
2001-2013 model year V70
10-24-2013 09:13 AM
