Small explosion and coolant into cabin
Old 07-18-2020, 12:24 PM
Boon Kij's Avatar
Default Small explosion and coolant into cabin
Hi I have a 1999 V70 station wagon with 110K miles. Driving on a hot day with the AC on, there was a load boom and the cabin was filled with steam and coolant flooded onto floorboards. The engine still had good power so I hobbled into a mechanic. His diagnosis after a cooling system pressure test was a blown head gasket, but he was not sure. Is it possible a coolant hose burst near the from so coolant came into the cabin, and not a head gasket problem? Any ideas would help. Thanks.
Old 07-18-2020, 03:42 PM
Your heater core broke, and leaked antifreeze into the car. And if you drove it far enough (does not take much) without coolant you could have damaged the head gasket. Or head gasket was previously damaged, your radiator cap pressure relief valve did not work and the pressure found the weakest part.
Disconnect the heater hoses from the firewall under the hood, block/clamp them off or connect them together somehow so the system will hold pressure. Then you can test for a blown head gasket. Or start the car and see if water (don't buy coolant yet, you may need it for your next car) will stay in it once the hoses are connected/blocked off.
However when a car has an extremely blown head gasket the coolant bottle has a distinct smell, and with really bad ones the spark plug cover melt/gets deformed, worse on the exhaust side of the engine.
Old 07-18-2020, 09:02 PM
definitely an issue with the heater core or the hoses to/from the core - Volvos always run coolant through the heater core using blend doors to control the heat. With that said, you could still have an head gasket issue as the root cause for why the heater core/hose blew out. If the head gasket allows exhaust gasses to get into the coolant chambers you'd get very high pressure in the cooling system which can blow out the pressure cap or pop a hose. There's a test that measures HCs in the coolant to detect if the head gasket is leaking. Check with your tech to see if they did such a test.
Old 07-19-2020, 11:35 AM
Boon Kij's Avatar
Default Thanks Hoonk.
Thanks much for your very thorough reply Hoonk. I will explore further with the mechanic. Boon
Old 07-19-2020, 11:36 AM
Boon Kij's Avatar
Thanks for your suggestion mt6127. Very useful brother. Boon
TWSeatbelt
05-15-2020 03:08 PM
V70volvolover
03-02-2016 10:42 AM
volvamos
01-10-2012 12:52 PM
91740Turbo
07-04-2011 08:28 AM
lcjm225
12-25-2008 10:56 PM
Quick Reply: Small explosion and coolant into cabin
