Vibration through throttle pedal
Old 02-17-2017, 12:33 PM
Warrior150's Avatar
Default Vibration through throttle pedal
hello.
I own a 2013 XC60 D5 R design with 63000 miles on the clock. I purchased the car from a Volvo dealership in January 2017
I have recently had a new power steering rack fitted under warranty as the steering was pulsing while turning a corner. Even pulsed while stationary and turning the wheel
since the repair I have noticed a slight vibration / grinding feel through the throttle
pedal. And also the brake brake pedal.
It does not seem to do it on a perfectly smooth new section of tarmac.
Has any one had the same problem
many thanks.
Old 02-17-2017, 03:20 PM
does the vibration change with road speed? with engine speed?
Old 02-18-2017, 01:50 AM
Warrior150's Avatar
No it doesn't. It's a constant.
I don't think it's a rotational vibration. It's almost like something is rubbing the bulk head and transmitting vibrations through the pedals.
If you go over a more rough surface it is worse.
And it is only since the steering rack was replaced.
It's very strange.
Old 11-18-2018, 07:58 PM
cscaife72's Avatar
Did you resolve this problem? What was the cause? I am experiencing something like this on my 2011 XC60, 61,000 miles but when I took it to the Volvo Service, the mechanic did not feel the vibration in the pedals whenever he drove it. I appreciate your help.
Old 11-20-2018, 02:28 AM
Warrior150's Avatar
Hello
I also took my car to a Volvo garage and they also didn’t not find anything or could not feel the vibration
I still have this issue. I don’t think the technicians can feel the vibration due to the work boots they wear.
I have noticed that I cannot feel it when I wear my work boots.
Sorry i can’t help you with this.
Joseph
S70driver
09-08-2023 09:47 PM
dwenrhod
04-10-2015 09:44 AM
Jomo1
09-08-2012 11:23 AM
Bowman
03-18-2008 11:18 AM
thullz
03-05-2008 07:11 PM
Quick Reply: Vibration through throttle pedal
