slight vibration in gas pedal
Old May 11, 2006 | 12:18 PM
thullz's Avatar
Default slight vibration in gas pedal
Hello,
I just bought this car yesterday and have been noticing a slight vibration in the gas pedal at low speeds, it goes away as you speed up to over 20kmh. The vibration is more pronounced if I accelerate very gradually from a stopped position.
I havent had a chance to drive this car too much just yet but the vibration is bothering me...could it be a spark plug issue? The car runs smooth otherwise, idles great and accelerates just fine, although there may be a slight shudder accompanying the pedal(car) vibration until the car shifts into higher gears and speeds up.
Another quick questions...are the injectors a bit loud in these cars, I have an 01 base S60 and the lifters sound a bit loud.
Thanks for your help folks!
Cheers!
Old May 11, 2006 | 08:52 PM
Default RE: slight vibration in gas pedal
Yes the injectors are loud on these cars.
You might have a bad engine mount.
Old May 12, 2006 | 01:50 AM
thullz's Avatar
Are engine mounts expensive to change? The vibration goes away once the rpm goes over 1500.
Old May 12, 2006 | 07:01 AM
mingster's Avatar
I have exactly the same gas pedal vibration on my 2001 S60 non-turbo. Is this something critical to fix (i.e. safety issue or can cause more seriously damage) or I can ignore if it doesn't bother me?
Old May 12, 2006 | 08:44 PM
Some of the mounts are a little expensive.
But I would have them check and replaced soon.
Old Mar 3, 2008 | 06:30 PM
valiant67's Avatar
Hi thullz, mingster, and others,
I just posted a thread with almost the same problem with a vibration in the gas pedal on a 2004 S60. Did this get resolved with replacement of an engine mount? Or did you find it was something else? Thanks for any information.
Old Mar 5, 2008 | 07:11 PM
mingster's Avatar
Hi Valiant67,
I didn't do anything to address the problembut haven'texperienced the problem for the last few months. I am not sure if I will replace the engine mount unless the problem comes back and persists.
thanks
Mingster
danieldenn
Sep 2, 2012 04:44 PM
orig_nautique
Aug 30, 2009 06:54 PM
gatorbrit
Dec 2, 2008 09:11 AM
ocean238
Apr 17, 2008 06:20 PM
valiant67
Mar 4, 2008 03:27 AM
