Sponsored by:
Sponsored by:
Dash Noise-Squeeky
Old 03-11-2010, 09:22 AM
BikerJohn's Avatar
Default Dash Noise-Squeeky
Hello everyone.
I searched but could not find any threads regarding a "squeeky" or noisy dash.
I have an '07 V8 and have noticed that at certain temperatures that the material of my dash up where the front defroster vent is makes a squeeking-material-rubbing-rattling kind of noise.
Has anyone else experienced that?
I've removed the center speaker grill to see if I can access that area where the windshield meet the dash but no luck. The front defroster grill/hvac housing is in the way.
Would anyone know how to remove the front defroster grill? I managed the pop off the 2 ends and the center trim but I don't know how to remove the main grill/mesh.
Anyone?
Thanks,
John.
Old 03-14-2010, 12:47 PM
Danilosilni's Avatar
I had the same problem on the drivers door, mainly around the handle. What i did was just spray WD-40 along all of the edges where the pieces of the door meet and that solved my noise.
Old 03-14-2010, 03:16 PM
BikerJohn's Avatar
I thought about that. However it sounds like its coming from a little deeper within the HAVC system. I think I'll give it a try in certain spots to see if that helps.
Old 03-21-2010, 03:46 PM
raychandler's Avatar
Guys,
Give in. Every second XC90 does this sound. Recently I have my 2nd XC90. First started after 10000 miles.
Old 04-22-2014, 05:42 PM
Yukon Jack's Avatar
My 2008 XC90 was squeaking terribly most noticeably when using the air conditioning. I bought a 2 1/2 foot long piece of rubber hose, about 7/16" to 1/2" diameter and stuffed it between the windshield and the dash and this completely solved my squeak.
Old 07-03-2014, 02:12 AM
mclaing's Avatar
Huh. so has anyone found the source of the squeak? I would really like to get rid of it too. My perfect XC90 drives like a dream and then begins the squeak, usually when the car has passengers that love to point it out.
92_240_sedan
04-30-2011 11:04 AM
Nataku
06-03-2009 07:45 PM
jbest817
04-21-2009 11:05 AM
tr_car_nut
01-19-2008 09:37 AM
Psaboic
08-15-2006 02:50 AM
Quick Reply: Dash Noise-Squeeky
