Sponsored by:
Sponsored by:
XC90 Loud gurgling, vibratory sound at high speeds, P0192 and P0193 CEL codes
Old 12-29-2016, 10:06 AM
marlonl's Avatar
Unhappy XC90 Loud gurgling, vibratory sound at high speeds, P0192 and P0193 CEL codes
Hello all, any and all advice is greatly appreciated.
I have a 2011 XC90 AWD 3.2 liter. it has 104,000 miles on it.
I have a check engine light on and went to read the code and it comes back P0192 - Fuel Rail Sensor A and P0193. I am going to bring the car into the shop on friday, but wanted to get input from this community as to what may be the issue.
Additionally, when I am driving i get a loud vibratory, almost acoustic sound or when i am up to speed and either driving straight or slightly right. the sound goes away when i am turning left. I am not sure if these two issues are correlated.
Thanks in advance,
Marlon from Philly
Old 01-01-2017, 11:46 AM
masscomguru's Avatar
The fuel rail sensor is easy. The noise you are describing sounds like a front wheel bearing. also, not too bad.
Old 03-12-2017, 10:17 AM
ShawnM 02 V70's Avatar
I was experiencing similar sounds when accelerating from 1rst to 3rd gears. Ended up being a couple of worn pulley wheels on the engine and worn mount bushings on the torque arm which is on the passenger side of the motor connecting it to the strut tower.
apexnut
02-02-2010 08:42 AM
walter351_
07-05-2009 11:02 AM
bocaboca
11-22-2008 09:00 AM
jonnyboyca
02-11-2008 11:59 PM
oragame
07-21-2005 11:42 PM
Quick Reply: XC90 Loud gurgling, vibratory sound at high speeds, P0192 and P0193 CEL codes
