1998 v70 cx awd Driveshaft
Old Oct 1, 2012 | 03:21 PM
Scratchy2000's Avatar
Default 1998 v70 cx awd Driveshaft
I understand that one can remove the driveshaft without much effect and simply going to FWD. I suggested this to my mechanic and he seemed horrified. His biggest concern was what happens to the gaping hole left at the transmission once the driveshaft is removed? Any answers would be greatly appreciated.
Old Oct 7, 2012 | 10:42 AM
Ozark Lee's Avatar
The driveshaft (propshaft) bolts up to flanges on both ends. It isn't like a Chevy where you have a splined connection to the transmission or transfer case output. The transfer case in Volvo speak is also called an angle gear or a bevel gear. In short, you can remove the propshaft with no other ill effects beyond no all wheel drive.
Save the old driveshaft, they are obscenely expensive even for a core to send in to get it re-built. You can get the propshaft re-built and balanced at Colorado driveshaft for around $300.00 net, after the core is returned.
...Lee
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
Rntsm
Jan 26, 2013 03:44 PM
ABVO850
1998-2000 model year V70
Jan 21, 2013 10:33 AM
awdMN
Nov 28, 2010 09:08 PM
kturner3
Feb 17, 2009 07:22 PM
