Warning light
Old Oct 6, 2012 | 03:23 PM
mollys12's Avatar
Default Warning light
HI guys i recently bought a 1997 v70 t5 se , 213000 miles on clock , today a warning light came on and i dont know what it is , i've never seen one like it before , its in a triangle and it has a crooked line on one side and and straight angled line on the other both leaning towards each other .
anyone know what this means ??/
it looks a little like this ,\
Old Oct 6, 2012 | 04:21 PM
Willvo's Avatar
If it looks like this:
http://www.justanswer.com/uploads/eu...ambdalight.jpg
it's an emissions system light. Possibly a problem with the catalytic converter or fuel mixture.
Old Oct 6, 2012 | 04:30 PM
mollys12's Avatar
hi , yes thats the light , thank you for your answer , is it a major problem ?
Old Oct 6, 2012 | 06:27 PM
Willvo's Avatar
It could be major, but it probably isn't. I've heard that most often they are caused by the fuel filler cap not being screwed on tightly enough, or leaking slightly and letting some air into the fuel system. Not a big deal. Second most common is a bad O2 sensor, which could be one of 2 in the car. These are usually $100-200 and can be installed by any garage. They can check the car's error codes to tell for sure.
For right now, I'd say just make sure the gas cap is tight and see if the light goes away in a couple days.
Old Oct 7, 2012 | 11:14 AM
Ozark Lee's Avatar
The Lamba light is the same as a check engine light but it wasn't used in US specification cars. The Canadian and European versions got the lambda light. It could be a big deal or not a big deal. Get the codes read and post them back. Many of the auto parts stores will scan the car for free but their printout tries to out think things and prints off a suggested, usually expensive, part that should be changed. What you need to get is the P code number. It is a code that starts with the letter P and is followed by 4 digits.
...Lee
97-850Wagen
Sep 10, 2013 10:40 AM
TDolce
Oct 26, 2007 05:52 PM
Gordon
Jun 28, 2007 09:26 AM
andy2812
Jan 22, 2005 12:32 AM
fopdod
Jan 18, 2005 06:45 PM
