1998 v70 Speed Sensor Install Inquiry
Old Mar 13, 2012 | 12:47 PM
brentlymd's Avatar
Default 1998 v70 Speed Sensor Install Inquiry
I just bought a 1998 v70 wagon in great condition. The ABS and Tracs lights are on, as well as the check engine. I was told by the dealer that it required a new speed sensor part and was given the part. Now I need to install the part. Any DIY tutorials or instructions would be very helpful as to where to find this part and install a new one, if that fixes the issue. I have read about the ABS units failing on this year/model. That may be next approach if this sensor doesn't fix it. I'm attaching a photo of the part. Thank you in advance for your help!
Attached Thumbnails 1998 v70 Speed Sensor Install Inquiry-volvo-sensor-web.jpg
Old Mar 13, 2012 | 12:49 PM
brentlymd's Avatar
And in case you can't read it, the part box label reads "AltronSpeed Sensor 3515266 G/C:120 F/C: 10" if that helps. Thank you!
Old Mar 13, 2012 | 10:11 PM
gdaley's Avatar
Default Probably not your problem...
You probably need to have the ABS module repaired. My S60 needed a speed sensor when I bought it. The CEL was on and a scan showed transmission codes specifically identifying the input shaft speed sensor, No ABS/TRACS lights. I would ask to have the car scanned and the codes given to you even before swapping the speed sensors (which is a piece of cake). Any time you have an opening into the trans exposed there's the possibility of something falling into it. There's a guy who fixes the module for $55. Don't know the rules here about mentioning service providers that aren't "supporters" of the site as I just joined. He's not hard to find though and does a great job. The module is easy to R&R and you can use the car in the meantime.
jagtoes
Apr 10, 2015 07:12 AM
Vxc90
Feb 13, 2014 11:34 PM
Cryin'Shame
Apr 15, 2011 12:43 AM
TRAV1S
Sep 4, 2010 03:29 PM
willkeepscool
Nov 24, 2008 04:20 PM
