1999 V70 question
Old May 23, 2019 | 03:11 PM
llojac66's Avatar
Default 1999 V70 question
Was driving down the road temp light came on. Stopped and checked the oil. It was low so put oil in light went off. Drove a little bit farther light came on and there was oil all over rear window I believe coming out the exhaust. Anyone have an idea what is wrong? Was told it was the front seal...but want to be sure. Thanks in advance for the help!
Old May 24, 2019 | 01:14 PM
Check the turbo area - if there's oil all over the rear of the engine and underside of the car, its likely the turbo oil return line seal. If the engine is clean and the oil is inside the tailpipe and your plugs look clean, then its likely the turbo shaft seals (time for a turbo rebuild).
Thang Vora
2001-2013 model year XC70
Jun 23, 2018 11:13 AM
rolling2
Feb 12, 2012 05:45 PM
ddrewyor
Feb 16, 2010 07:48 PM
Alex867
Mar 14, 2008 12:51 PM
typhoon55
May 24, 2005 12:53 AM
