1999 V70 Smoke in the morning
Old Jun 29, 2014 | 06:40 PM
kawish1659's Avatar
Default 1999 V70 Smoke in the morning
Hi, I have a 1999 V70 XC with the 2,4 Turbo when I start the car in the morning there is some smoke coming out from the exhaust pipe end and to me it seems like it is the Valve seal that are getting old so they let some oil goes thru when the car sit for a while but the thing is that it is not every morning and that really confusing me does anyone can help me with that problem ?
Old Jun 29, 2014 | 07:07 PM
difflock54's Avatar
Blue smoke or simply whitish/streamy more condensation?
Old Jun 30, 2014 | 06:58 AM
kawish1659's Avatar
Blue smoke I can tell that is oil smoke
Old Jun 30, 2014 | 06:59 AM
kawish1659's Avatar
Blue smoke from oil but not every morning that is confusing
Old Jul 2, 2014 | 07:48 PM
difflock54's Avatar
Would it (your oil smoke observations) coincide with having only done very short trips/short duration as opposed to a good long highway run with a hot motor immediately prior?
Old Jul 3, 2014 | 08:32 PM
kawish1659's Avatar
Yes short trip every day
Old Jul 4, 2014 | 06:24 PM
difflock54's Avatar
The PCV system would be worth a check. Test for crankcase pressure using the glove test on the oil filler opening.
Short runs will cause the motor to sludge up over time and a build up of condensation in the oil also occurs. The latter often is noticeable if you have a buttery cream showing on the dipstick just below the sticks 'O' ring seal.
Sometimes that is mistaken for a blown head gasket but is merely the condensation issue.
A good long hot run, regularly keeps the condensation from occurring.
If it is actually the PCV system and especially blocked up engine ports where the oil trap is connected any excessive crankcase pressure may be forcing oil uo past the valve stem seals, hence the blue exhaust smoke.
A higher mileage motor is likely to have less effective stem seals anyway.
Blocked PCV systems can eventually cause cam seal failures or rear crankshaft main seal failure also if it gets bad enough.
royalslover
Sep 20, 2019 02:43 PM
jeffreydoctor
Jul 14, 2010 10:06 PM
volvolove
May 20, 2007 07:07 PM
veso_ht
Apr 30, 2007 02:42 PM
tomskuce
Nov 27, 2006 08:12 PM
