2000 V70 - All at once coil codes: 3310 3320 3330 3340 3350 plus code 3200
Old Sep 18, 2023 | 12:15 PM
mizer's Avatar
Default 2000 V70 - All at once ECM coil codes: 3310 3320 3330 3340 3350 plus code 3200
Hey all. I have a 2000 V70 with 128K miles on it. Seems to run fine, decent smooth power, sounds and feels okay under acceleration. My son drives it. The other day CEL came on and it had thrown codes ECM-3310 through ECM-3350, plus code ECM-3200 (6 codes). Those codes report ignition coil faulty signal. If I clear them they all come back, pretty much immediately. The thing that gets me is it's ALL the coils all at once. I replaced all the coils a few years back, as it was throwing some codes back then (don't remember which code - but pointed to coils), and since then no more coil codes. For this new problem I have inspected the wiring harnesses to the coils, and coil plugs. Wiring and connectors all appear healthy and clean. I also checked the engine +12V relay, and it seems to be delivering full battery voltage while engine is running. I'm thinking some ECU pins corrosion problem?? Or what?
I have purchased the ECU removal tool, it's on it's way, so I can remove and inspect the ECU pins/connectors. Any other ideas appreciated?
Last edited by mizer; Sep 18, 2023 at 12:32 PM. Reason: Update title, more precise info
Old Sep 28, 2023 | 03:55 PM
mizer's Avatar
Soooo, I took a somewhat shotgun approach and replaced all the coils and plugs. I decided to buy Bosch coils, and Volvo plugs. I've learned over the years, especially with GM vehicles that aftermarket parts can be real junk. The coils that are in this V70 are some off name, probably chinese parts. I also wrapped the entire coil wiring harness with high temp loom tape I bought on Amazon [BTW this loom tape is really good stuff - been using it for a while now - an it's surprisingly inexpensive]. Anyway, those steps worked. I cleared the codes and none of them have returned - been a week now.
Link to the loom tape:
Tesa's Most Advanced High Heat Harness Tape 51036
https://www.amazon.com/dp/B01I2MLN2Q
Cheers!
Old May 22, 2025 | 06:49 PM
CaptCal 88's Avatar
Default I know this is an old thread but...
I got no codes for individual coils, just the code ecm-3200. Any ideas?
Old May 22, 2025 | 06:51 PM
CaptCal 88's Avatar
JC66
Oct 2, 2021 01:08 AM
lukaspanic
Mar 19, 2011 09:13 PM
chimmychong
Apr 2, 2008 08:34 AM
wholesale boxes
Sep 26, 2006 09:06 PM
bluewindspeed
Sep 7, 2005 09:08 PM
