2000 V70 XC misfire or hesitation at cruising
Old Aug 29, 2017 | 12:42 PM
beaudrox's Avatar
Default 2000 V70 XC misfire or hesitation at cruising
Hello,
I'm new to the forum and to working on this car. I'm experiencing a subtle lag or hesitation (possibly misfire) while cruising (50-60mph). It occurs with the AC on and off, but worse with it on. Car accelerates fine. No current engine codes. Recently replaced spark plugs. Any ideas? Thanks!
Old Oct 26, 2017 | 08:45 AM
worklist's Avatar
I had this happen on a 1998 V-70. At around 60 MPH it would feel like misfire, no codes displayed. Thought it was a throttle control issue, turned out to be a cracked distributor cap. Not sure it they still had these in 2000 though.
Old Oct 26, 2017 | 10:52 AM
Oodlemi's Avatar
Can we get any more information. Is it lacking power? Does it do it once or multiple times like a misfire/running rough, bogging down? Is it an automatic (maybe you're feeling the Torque Converter Clutch kicking in)?
Old Oct 26, 2017 | 03:11 PM
ramar's Avatar
i have the same issue in my 1998 V70. my car has a distributor, but i had a late 1999 that didn't, it had a coil at each spark plug, which works better than having a distributor. i replaced the cap, rotor, plug and wires. i have two other issues, the battery light comes on at high RMP and a warning code associated with check eng light. the code indicates lean mix in bank 1 which might be an O2 sensor. but i guess am going to replace the ignition coil to try to address the misfire at cruising speed. i am not going to use the bosh for $127 USD, instead i might try
Amazon Amazon
no brand name accept possibly Ena? i am also replacing the voltage regulator if i can't get it to function, with a Huco brand from Germany.
Old Oct 26, 2017 | 04:45 PM
worklist's Avatar
If you do have a distributer, check the cap, or just replace it and the rotor if original. The car I am working on now has 127K miles, and clearly never had these replaced.
On the previous '98 V-70 that misfired at 60MPH, I was still taking it to a pretty good indy erurocar mechanic. Took him a bit to figure it was the distributor cap. Some of the younger techs, even if good, barely know what one is. Us old timers remember they are a wear part and need to be replaced now and again. All those electrons erode the metal contacts after a while.
ramar, try rock auto, you get a choice of several grades of any given part, and you can pick the brand.
V50LBC
Dec 14, 2011 03:51 PM
nola740T
Oct 6, 2010 11:43 PM
yellow95
May 9, 2006 09:58 PM
johnoswald
Jan 9, 2006 08:50 PM
