99' v70 stall issue...
Old Jul 1, 2012 | 07:38 PM
DANNY25SS's Avatar
Exclamation 99' v70 stall issue...
Good afternoon all,
I am newely reg. to this forum, though have visited many times for information. You all are great!
I have an issue with my 99 v70 2.4. At any given time and temp it will stall out when coasting or breaking to a stop. Have had no codes pop up or stored until the other day a lean exhaust code came up. After it stalled out hours later when giving it a rev on restart it went out. could an O2 sensor be bad? I have replaced the fuel pump, filter, and I cant remember the name but its the small air relay that comes off the inlet to the throttle body and feeds into the intake above the fuel rail. I cleaned that a month ago and it seemed to go away and bam back with a wrath. It stills 200 feet down the road from my driveway or 20 miles... Please heeeeelllllpppp....
Thank you in advance,
Danny
Old Jul 3, 2012 | 08:42 PM
DANNY25SS's Avatar
Anyone?
Its now doing this going down the road cuts in and out no pattern at any speed... Any ideas from those who have "been there" already?
Old Jul 13, 2012 | 12:19 AM
1977stevo's Avatar
It's your etm (electronic throttle managment) look it up just take the air cleaner out and the hose to your etm and spray throttle body cleaner or maf/map sensor cleaner all in the throttle body/etm and stick a toothbrushsh down in there and scrub around and squirt and scrub some more. Put it all back together and it should run better I bet it won't stall or not as often. Worked for me $5 dollar fix in 15 mins.
Old Jul 13, 2012 | 12:21 AM
1977stevo's Avatar
Btw I have a v70 2.4 non turbo 1999
gedaggett
Feb 11, 2013 07:34 PM
laser166866
Jan 27, 2011 06:56 PM
jwandhistools
Aug 11, 2009 09:43 AM
shoebox92
Mar 23, 2009 11:24 PM
wild wane
Apr 19, 2006 10:11 PM
