99 V70R AWD with rear driveshaft removed?
Old Apr 6, 2012 | 12:08 PM
ABVO850's Avatar
Default 99 V70R AWD with rear driveshaft removed?
So I am in the market to buy a VO station wagon. I want either an 850R wagon, V70 T5 or V70R AWD if I can find one. I saw one on sale that advertises the rear driveshaft being removed so runs only on front wheel drive.. Is this ok? Im curious as to whether this can be a permanent modification or will it cause long term damage?
Old Apr 11, 2012 | 09:16 PM
My guess would be that 70% of AWD shafts in the '90 model awd cars have been removed. No problems running these as fwd.
Old Apr 12, 2012 | 09:39 PM
ABVO850's Avatar
Was there a fault in the earlier AWD systems? The 98 V70 R AWD that I've found looks clean and id like to make a move on it if it checks out although it is missing the rear driveshaft.
Old Apr 12, 2012 | 10:00 PM
ABVO850's Avatar
Seems to be issues with the VC from what I've seen online.
Old Apr 12, 2012 | 10:07 PM
The thing about it is the cost to fix it when it has issues is about $1,200. Many people choose to ditch it vs fix it. They aren't that bad, just need to make sure your tires are all the same size when it's in place or it will cause it to get damaged. Once the shaft is removed it's fine. No issues.
Old Apr 19, 2012 | 04:05 PM
mudpie's Avatar
I have a '98 V70XC that I bought two years ago with a bad driveshaft. The bearing was shot, as well as the universal joint. I pulled it out and put 57k miles on it with front wheel drive. No problems.
Now I'm selling the car, so the driveshaft had to go back in. You won't find a driveshaft anywhere except the dealer, and it's expensive, as mentioned above. There's a place in Colorado that rebuilds them for about $500 if I recall, but you gotta pack yours up and ship it off to them.
If the CV boots on each end of the shaft are good, the remaining parts can be had for about $60. Pulling, repairing, and reinstalling takes maybe a couple hours. If you need the boots, they're about $25 a piece, and whatever time it takes to repack a CV joint.
Old May 10, 2012 | 02:32 PM
ben watson's Avatar
Hi there i have a v70 2.5 turbo awd and its been no probs untill i broke the angle gear. It is a 1998 model which is prone to probs with the awd system or so i have been told. I replaced the gearbox when i bought it and its been fine untill the angle gear broke last week some later models have electrics and the earlyer ones are mechanical which has a angle driven prop from the diff to a vicious coupling on the rear diff not much to go wrong with them to be fair but i do advice using volvo oils in all transmission components and then you cant go wrong
Old Jan 19, 2013 | 09:54 AM
rgutkin's Avatar
I bought a 98 AWD. The timing belt broke the next day. The seller told me the belt was changed recently. My mechanic told me the kit wasn't replaced. Also the seller didn't tell me the driveshaft was removed. The seller told me the lights don't come on and the car will pass inspection. The same day the lights came on and the car won't pass inspection. Does anyone believe the seller should return my money?
Old Jan 21, 2013 | 10:33 AM
mudpie's Avatar
In a perfect world, that would be nice, but I wouldn't count on it happening.
MoneypitC70
2001-2013 model year XC70
Oct 26, 2014 08:37 PM
hockeyfool
1998-2000 model year XC70
Aug 13, 2014 01:15 PM
hockeyfool
Aug 12, 2014 06:20 PM
Eero W
Feb 17, 2014 10:07 AM
ekugler7@msn.com
Jun 21, 2010 04:34 PM
