ABS & TRACS light on for no reason
Old Feb 27, 2017 | 06:57 AM
StephenV70's Avatar
Default ABS & TRACS light on for no reason
Hi all,
I have a 1998 V70 AWD - generally in good working order, 80,000 miles.
The problem is that ABS and TRACS dash lights come on for no apparent reason after a few minutes of driving. Often there is a whirring noise and slight vibration through the brake pedal before the lights come on.
The people i bought it fromsaid their volvo garage and looked at it for several days and found no problem - the lights just appeared to be coming on for no reason.
I have had the ABS unit replaced at a volvo specialist garage, but that's not fixed it.
My local garage, which is very good but not a volvo expert, ran a diagnostic and it came back showing three of the wheels were faulty, which is extremely unlikely. They think it's a wiring/electrics problem rather than an ABS problem.
Unless i can fix it, it prob won't make it through its next MOT.
Any suggestions? I'm not experienced enough to make any fixes myself, but would like to be able to point the garage in the right direction, as they're stumped.
Cheers all
Old Apr 1, 2017 | 06:12 PM
Was the module replaced with a new one?
Old Apr 17, 2017 | 10:21 PM
Check out Victor Rocha's web site for some good info - what happens is the ABS controller circuit boards are prone to cracks in the solder joints leading to intermittent fails (ie as the board heats up with driving). Different model Volvos present differently but the fix may be to have your controller repaired. Several shops offer this service.
Old Apr 29, 2017 | 02:56 AM
Flippy Brian's Avatar
I had this happen and i replaced my abs module. What happens is the solders in the mudle go bad and need to be reslodered or have someone who know what theyre doing solder it.
shoter_hellas
Nov 27, 2011 11:06 PM
Barrie
Apr 17, 2010 04:59 PM
850GLE
Sep 22, 2009 10:28 AM
paulh
Jan 30, 2008 08:22 PM
jack2403
Jan 4, 2007 08:43 PM
