Engine turns off when making a stop. Need advice and help.
Old Apr 15, 2016 | 09:29 PM
ineedhelpvolvopeople's Avatar
Exclamation Engine turns off when making a stop. Need advice and help.
Hi guys, I own a volvo v70 se year 2000, and I'm having issues recently. Each time I make a stop at a red light or stop sign, the car's rpm drops to around 200-500 and shuts down with the oil light, battery light. What seems to be the problem? Please comment below. THANK YOU SO MUCH!!
Old Apr 17, 2016 | 07:21 PM
rough idle/stalling can point to one of a few things - ETM (electronic throttle body) are usually the first suspect, a vacuum leak or the idle air valve (the latter two can mess up the air mixture at idle). Time to clean the ETM and IAV and inspect vacuum lines/intake tubes. The oil/battery light are coming on because the engine is turning too slow for the alternator to produce enough voltage...
Iggyomega
Apr 10, 2020 07:23 AM
Stb7
Nov 6, 2013 09:12 AM
Aarondawg
Jul 10, 2012 10:21 AM
Dj Eterno
Mar 13, 2008 07:53 PM
