99 v70r ets?
Old Apr 18, 2016 | 08:58 PM
280zxNick's Avatar
Default 99 v70r ets?
So the other day I installed a new bypass valve from IPD because I suspected an issue with the factory bypass valve. After completing the install I went to start the car to check my work. The car is now throwing a bunch of lights RPM gauge works for a couple seconds then stops working but i can tell its idling high maybe around 2,500 rpm or so. I double checked my work and everything seems to be hooked up correctly. My ETS light is on and i can here it humming from the engine bay is this just coincidence that the ets goes out right after I finish?? Checked codes and im getting P1631 and P1633 both for "Accelera Pedal Pos Sensor 1 and 2" High signal and the other is signal to low? I don't really want to go out and buy a new ETS and that not be the issue. So im here hoping for some words of wisdom lol. Thanks in advance [IMG]Name:  YTrks2r.jpg
This is with the car running
Old Apr 19, 2016 | 01:18 PM
I've seen other posts where the cause was either the speed sensors at the wheels or the ABS module. Are you seeing any lights for the ABS or Tracs? Does your cruise control work properly or show that its on?
Old Apr 19, 2016 | 02:19 PM
280zxNick's Avatar
The ABS light is on and yes cruise control works
Old Apr 19, 2016 | 09:37 PM
firebirdparts's Avatar
You might want to check your voltage. At least some of those lights go into test mode when the alternator is not on, and some of the other flakiness might be cause by low voltage. It's also easy to fix, if that turns out to be the problem, so that's good.
cboinc
Mar 16, 2010 05:53 PM
cboinc
Mar 13, 2010 02:17 PM
ahmedmu
Sep 17, 2004 12:31 AM
louduva666
Aug 23, 2004 06:38 PM
Terence
Feb 20, 2004 02:03 AM
