View Poll Results: Should I take the car?
Yes, it's worth the investment!
0%
No, not worth it!
33.33%
Sell it for parts
66.67%
Voters: 3. You may not vote on this poll
Free V70, should I take it? (There is a catch to it though)
Old Mar 6, 2015 | 12:52 PM
Guti776's Avatar
Exclamation Free V70, should I take it? (There is a catch to it though)
A friend is offering to give me her '99 V70. She was going to donate it to someone/something so she asked me if I wanted to take it.
Heres the back story:
The car has about 200k miles on it. One day she was driving it and it shut-off on her (the car overheated on her), she tried to turn it back on and it eventually did. She was able to drive it to a near by gas station. They checked the oil and it was fine, the coolant was empty though. They re-filled the coolant and she drove it home with no problem.
She took it to a local mechanic, they put a die in for the radiator to see where it went. Turns out the car has coolant in the oil. She can drive it but she has to re-fill it with coolant on every trip (relatively short trips) and there are no visible leaks. Basically, the car is driving but obviosly has a big issue.
Could it be any of these or other problems:
The head gasket
The oil cooler in the radiator
Cracked block
Etc
Any suggestions to what to look for?
Just curious to what I'de be dealing with if I decide to invest the time and money into it. I think the worst case scenario is that I sell the car for parts as long as I don't invest more in the car than I can get for it if I sell it.
So, question is: Should I take the car or not? Think its worth fixing?
I appreciate any feedback/help on this.
(I could use another car right now and its not everyday someone just gives one away like this)
Thanks,
Old Mar 8, 2015 | 02:37 PM
worst case scenario is the head is cracked and needs to be swapped out. Likely causes are head gasket or a cracked cylinder head. Assuming the worst, you can get a used head installed in the $1500 range - less if you do the work (a used head goes for $500 or so). The car is probably worth $1500 to $2000 in working order so I'd say if you can do the work its a deal, if you need to pay a shop, then I'd take a pass.
PinnacleWax
Jul 26, 2016 01:21 AM
PinnacleWax
Feb 16, 2015 04:27 PM
Squiggy
Nov 8, 2009 12:50 AM
rspi
Jun 25, 2009 06:52 PM
MotorCityAutoParts
Dec 28, 2007 09:59 PM
