Fuel pressure falls over night, have to prime 4-5 times or just crank for ever
Old Oct 17, 2020 | 03:56 PM
Granthb's Avatar
Default Fuel pressure falls over night, have to prime 4-5 times or just crank for ever
New to the forum, long time Volvo owner.
I recently replaced the fuel filter with a 122827 - Mahle - Fuel Filter - P80 850 S70 V70 C70 - 30671182 from IPD.
in the mornings when I start the car, or it has been sitting longer than 2-4 hours, I have to prime the system by turning to ignition multiple times. I can hear the fuel pressuring in the system from the back of the car forwards
edit: 1999 Volvo v70 wagon 2wd non turbo
Old Oct 17, 2020 | 04:17 PM
Fuel pressure may be leaking down due to a bad fuel pump check valve or the pressure regulator on the other end. Verify leak down with a fuel pressure gauge. Isn't there a rubber hose on the exit of the fuel pressure regulator - you could easily block the pressure regulator exit to verify if it was the fuel pump loosing the pressure.
BCFischer
1998-2000 model year V70
Feb 21, 2019 03:52 PM
1995Volvo850
Apr 6, 2013 03:54 PM
paulo215
Sep 12, 2011 11:39 PM
rolling2
May 30, 2011 11:16 AM
FASTER
Nov 13, 2010 09:07 PM
