notched pickup wheel for ABS sensors-source?
Old Dec 6, 2022 | 12:34 PM
Old Iron nut's Avatar
Default notched pickup wheel for ABS sensors-source?
Any one out there have a source for the notched pickup wheels on the front axle of a 1998 Volvo V70 (base model)? These are used for the ABS wheel sensors. I have the sensors ordered and they will be here Friday. I removed the right front sensor and the notched wheel looks corroded, probably why the light is on for the ABS system. Dealer can get them but I feel they are a bit pricy. Many thanks in advance, Old Iron Nut.
Old Dec 6, 2022 | 01:00 PM
Dingus1's Avatar
Did they quote the entire hub? I am not sure if you can get the rings by themselves or not. Nor do I know if they are removable. Hub for the front is about $110 on FCP
Old Dec 6, 2022 | 05:33 PM
Dingus1, the wheels are separate accoring to my dealer. Items are an interference fit on the hub. Thanks, Old Iron Nut.
Old Dec 7, 2022 | 07:51 AM
Dingus1's Avatar
https://www.bostonvolvocarsparts.com...UaAoFPEALw_wcB
I think that is it if you want to use the volvo part # to find an aftermarket. Check fitment based on specs
cscaife72
Jan 22, 2023 06:40 PM
Jaska23
Aug 5, 2019 03:04 PM
mrduke
Feb 13, 2017 10:19 AM
b5254t
2001-2013 model year XC70
Apr 6, 2013 06:47 PM
waterkr1
Aug 30, 2007 05:44 PM
