random ignition problem
Old Aug 4, 2012 | 07:48 PM
neojinnx's Avatar
Angry random ignition problem
1998 v70R Hi, just wondering about a new problem I'm having...sometimes when i start the car the radio and a/c and other interior electrical equipment doesn't come on unless you wiggle the key does the whole key ignition need to be replaced or is this just a loose wire somewhere? thanks for any advice
Old Aug 7, 2012 | 01:45 PM
colt1911's Avatar
Default Ignition problems
Chances are it's the pin side (left side) of the ignition switch, it can be replaced by removing 4 star screws under the steering column below the switch, 2 more slotted screws on the switch and remove from wire harness, replace and put cover back on...just did my 850 and my v70...they are a common problem on these cars. You will need a long star screwdriver to get at 2 of the screws.
bobmason
May 14, 2015 12:26 PM
RCM83
Aug 18, 2013 09:15 AM
petmbro
Mar 17, 2013 12:50 AM
FamilyGuy
Apr 26, 2010 02:43 AM
