Thermostat Housing Will not seal HELP!
Old Dec 9, 2013 | 09:39 PM
sawtooth4x4's Avatar
Default Thermostat Housing Will not seal HELP!
I have just installed my second gasket on the thermostat housing. This is my only leak after doing a complete head rebuild.
I do not know why it will not seal. I used gasket glue and even put some thread sealant on my bolts for the thermostat housing. the gasket matched up perfectly to the housing.
The thermostat seams to seal fine. its just between the head and the housing.
Old Dec 9, 2013 | 10:52 PM
Is it cracked? I would get another one. 850's, 70's, and 960's will work.
Old Dec 10, 2013 | 11:37 AM
ES6T's Avatar
Did you try installing it dry? I've never used any "gasket glue" and never had a problem.
Old Sep 19, 2018 | 06:38 PM
chrisd111's Avatar
Default sOMETHING TO CHECK
DID ANY LONGER SCREWS from somewhere else get mixed up with the thermostat housing screws? Corrosion is an issue, sometimes Wurst super silicone on a clean surface works as a thought to solve your issue.
ses_volvo
Apr 3, 2018 10:31 PM
koko284
Jan 4, 2016 08:38 PM
Silver_Volvo
2001-2013 model year V70
Sep 8, 2015 12:18 PM
cheesenacho
Mar 5, 2012 10:58 AM
Pej
Feb 16, 2012 07:21 AM
