Leaking around thermostat housing
Old Feb 15, 2012 | 03:08 PM
Pej's Avatar
Pej
Default Leaking around thermostat housing
there is a slight leak of coolant(now turned to whitish stuff) around my thermostat housing? is that just the gasket that needs replacing?
I changed the thermostat myself about a year ago and I am not sure why this would happen.
thank you
Old Feb 15, 2012 | 06:54 PM
I had the same thing on a 960 and it was the rubber gasket on the edge of the thermostat. Did you change that when you did the thermostat? It should cost like $1.30.
Old Feb 15, 2012 | 08:00 PM
Pej's Avatar
Pej
you know I believe it came with my thermostat when I bought it at the Volvo dealer OR I am pretty sure I bought it with the thermostat because it was cheap and it made sense to change it. Maybe I put it in bad?
If that is what is most likely the problem though I am willing to just grab a seal and change it again to make sure.
Old Feb 15, 2012 | 08:04 PM
Pej's Avatar
Pej
wait are you talking about that ring seal around the thermostat or the actual gasket? I can't remember what was going on in there lol
Old Feb 15, 2012 | 10:30 PM
JRL's Avatar
JRL
Either the gasket or you have a cracked housing
Old Feb 15, 2012 | 10:47 PM
Yes, the actual rubber gasket that goes around the t-stat seals the deal.
Old Feb 16, 2012 | 07:21 AM
Pej's Avatar
Pej
ok.
thanks guys
Bboble
Sep 19, 2018 06:29 PM
Silver_Volvo
2001-2013 model year V70
Sep 8, 2015 12:18 PM
ajd6c8
Jul 28, 2009 10:28 AM
otlip
Aug 26, 2008 03:28 PM
ciao-rich
Jun 13, 2008 05:01 PM
