02 flood damaged.
Old Nov 5, 2017 | 10:21 AM
yarchlrl's Avatar
Default 02 flood damaged.
02, near mint but, dash is out and car cranks, almost catches but no start. one code in system... Throttle pedal circuit. Would that cause a no start condition?
Any ideas??? has fuel, has spark, has compression, new battery, new oil, filter, fuel filter and so on. Swapped the gauge cluster with a known good one , same issue, no dash...
Old Nov 6, 2017 | 03:33 AM
firebirdparts's Avatar
I don't know enough to help you. I would think if it has accurate metering it should idle, but I try to avoid the post-1998 models. obviously the throttle pedal circuit has to work. Without that you wouldn't be going anywhere.
natb
Jun 28, 2015 07:14 PM
vetteor442
Mar 23, 2013 03:34 PM
outdoor7or24
Sep 17, 2008 06:51 PM
Bruno937
Mar 22, 2008 09:55 AM
TranPlanner
Jan 14, 2008 05:16 AM
