Help Needed - Front Pwr Seat Seized from Flood Waters
Old Jun 28, 2015 | 03:12 PM
natb's Avatar
Default Help Needed - Front Pwr Seat Seized from Flood Waters
Our 1995 Volvo 850 got some water damage from the recent flood in Houston.
Enough water got on the interior to cause the passenger front power seat's motors and module to get wet . The seat motors must have shorted ( or the module) and it went all the way forward and the back seatback tilted forward as well. It's frozen in that position .
1) First problem I managed to get 3 of the 4 seat hold down bolts out. I cannot get the inboard front bolt out as the seat is frozen all the way forward ( over the bolt head). Any ideas would be appreciated?
2) I need to get the seat back and the seat back at a normal angle. Any ideas on how to do that with the electrics shot?
What are the chances it's only the module and not one ( or all 3 ) electric motors?
I would prefer to keep the seat- but assuming I can get it out may have to resort to a junkyard seat.
Thanks
Old Jun 28, 2015 | 07:14 PM
getting wet shouldn't permanently damage a motor so I'd be more inclined to think the memory module sent an error code to the chassis CPU. Did you look at all the fuses, circuit breakers (39/40) and any relays as well as wiring connectors? You should be able to pull codes - but I need to look
Found this diagram which may help
https://www.volvoclub.org.uk/tech/se...PowerSeats.pdf
Info on codes:
Test Mode No. 1 (Accessing Codes)
1) Power seat diagnostic system is operated via diagnostic unit “B”, socket No. 6, using button and test lead from diagnostic unit “A”. To access diagnostic system, connect test lead from diagnostic unit “A” to socket No. 6 on diagnostic unit “B”.
See Fig. 1. Press any button on seat controls for seat to be diagnosed.
2) Hold button down when turning on ignition, and keep holding it down for about one second longer. Ignition must have been off for at least 5 seconds before beginning diagnosis. Press button once to select test mode No. 1 and read codes. See POWER SEAT DIAGNOSTIC TROUBLE CODES table.
POWER SEAT DIAGNOSTIC TROUBLE CODES TABLE Trouble Possible Fault
Code
1-1-1 No Faults Present
1-1-2 Signal Position Sensor Motor No. 1
1-2-1 Signal Position Sensor Motor No. 2
1-2-2 Signal Position Sensor Motor No. 3
2-1-1 Signal Position Sensor Motor No. 4
1-2-3 Motor No. 1 Functions Although Equivalent
Button Not Activated
1-3-1 Motor No. 2 Functions Although Equivalent
Button Not Ac tivated
1-3-2 Motor No. 3 Functions Although Equivalent
1-3-3 Motor No. 4 Functions Although Equivalent
3-2-3 Fault In Stored Memory Position No. 1
3-2-2 Fault In Stored Memory Position No. 2
3-2-1 Fault In Stored Memory Position No. 3
3-3-1 (1) Wire Disconnected, Motor No. 1
3-3-2 (1) Wire Disconnected, Motor No. 2
3-3-3 (1) Wire Disconnected, Motor No. 3
1-1-4 (1) Wire Disconnected, Motor No. 4
1-4-3 Motor No. 1 Turns In Wrong Direction
1-4-4 Motor No. 2 Turns In Wrong Direction
2-1-4 Motor No. 3 Turns In Wrong Direction
2-2-4 Motor No. 4 Turns In Wrong Direction
4-1-4 Faulty End Position Calibration
Read more: Volvo 850 power seats with memory service manual
vetteor442
Mar 23, 2013 03:34 PM
jeffhestand
Nov 11, 2011 07:08 AM
rogue606
Feb 13, 2010 03:42 PM
Kaspir
Mar 23, 2008 12:01 PM
stever
Nov 29, 2004 10:57 PM
