06 V70 Roughness
Old Jan 10, 2019 | 02:50 PM
mgb-cccp's Avatar
Question 06 V70 Roughness
I've been trying to chase down an intermittant engine roughness on my 2006 V70 2.5T. Initially codes suggested ignition issues, but replacement of plugs/coils and fuel filter didn't resolve the problem. I'm uncertain of the best path forward and wanted to get y'all's advice before proceeding.
Engine is smooth for ~5 minutes after the first start of the day. When roughness begins it's present at idle, and most pronounced during acceleration. Roughness stops at about 3k RPM; I can avoid it by manually downshifting to keep RPM that high. There's a smell of gasoline when exiting after a bout of roughness; I haven't been able to localize its source.
Here are the codes that I pulled (link to PDF of the full reader dump)
Should I troubleshoot the Cyl 1 injector, or the pressure regulator, or is there something earlier in the fuel system that I should be thinking about?
Thank y'all for the help. I've read these forums for years and am happy to finally join in!
Everett
Old Jan 10, 2019 | 04:17 PM
things to do: 1) test the fuel pressure to see the PSIs at idle and when you rev the engine 2) inspect the J tube in rear by the evap canister and see if there's any fuel leak/smell back there. 3) any signs of gas leaking out of the top of the tank? 4) test injector #1 for connectivity to make sure its not just dumping in fuel - does the plug on #1 look normal? Consider swapping out the injector and installing a new fuel pressure sensor but you may also have an issue with the fuel pump seal on the top of the tank.
Old Jan 10, 2019 | 04:47 PM
mgb-cccp's Avatar
Outstanding--thanks! I've renewed the fuel tank seal gaskets and verified fuel flow from the pump unit, but haven't checked pressure. Will do that and your other suggestions and report back!
sj528
2001-2013 model year V70
Jan 8, 2019 11:07 AM
bigdaddyrdpjr
Sep 25, 2010 12:48 PM
juanesoto
Mar 5, 2010 10:08 PM
ian3
Jul 31, 2009 11:59 PM
JBVolvo
Oct 22, 2007 01:56 PM
