H7 (low beam) Upgrade?
Old Dec 24, 2018 | 03:55 PM
Mr_Detail's Avatar
Default H7 (low beam) Upgrade?
Hello gentlemen;
Can anyone tell me what H7 bulb you have used to replace the old fashioned straight "H7" with perhaps a LED H7 or something similar that won't cause an error message to show up on my dashboard? I want to upgrade my low beam bulb but do not want the hassle of error messages and the like showing up.
MERRY CHRISTMAS to all and to all a good night!
Old Dec 27, 2018 | 07:19 PM
Georgeandkira's Avatar
If you go the LED route prepare to be disappointed.
Badly engineered LED elements to start with
LED units which run HOT
Units with out-of-place LEDs which put light into the wrong place on the reflector causing bad patterns
Nowhere have I read a review of LED H7's which was good but things do change.
Go name brand...call/visit any seller first.
Old Jan 3, 2019 | 08:16 PM
pierremcalpine's Avatar
What georgeandkira said. I did the LED upgrade a few years back. Went through three expensive sets until one finally lasted without degrading noticeably. Yes the whiter light is cool, yes it’s easier to spot my car among others as the beam is unique, NO it gives no better light. Don’t bother, is my suggestion. Oh and the first set burned a hole right through the housing. And the resistors that the first vendor recommended also burned through anything they touched.
Old Jan 13, 2019 | 01:10 AM
Zmarsh's Avatar
Originally Posted by Mr_Detail
Hello gentlemen;
I put h7 LED's in my low beam, h1 in my foglights, and whatever the highbeam is as well. The white highbeam LED actually gives better clarity compared to the dull yellow, but I can't say the other ones are any better or give any visibility upgrade. I haven't run into any burning through of any housings, but the low beam h7's give me a dipped beam failure message - just get a CANBUS system or resistors to prevent that - but the resistors run hot, so be careful with placement.
Atelaroli
Apr 24, 2018 12:20 PM
osteovolvo
Apr 19, 2018 09:14 PM
breknraj
2001-2013 model year XC70
Nov 16, 2016 09:34 AM
Lela
Dec 2, 2012 01:52 PM
WickedAces
Jul 4, 2009 09:09 AM
