2001 V70 BIG oil leak from front
Old 01-24-2016 | 06:59 AM
mpe's Avatar
mpe
Default 2001 V70 BIG oil leak from front
I hope someone can offer advice on my non - turbo 2001 V70 oil leak.
It is trickling out at a fair rate off the rear corner of the sump nearest the belts.
The whole underside of the car is covered in oil and also the rear window (slipstream)
There is no oil anywhere on the belts - just a little dry dust.
There has been a slight squeal when starting just for a second recently but I don't know if there is a connection.
There is healthy suction at the oil filler (rubber glove test) and I have had the sump off and replaced oil cooler seals.
Leak is coming from higher than the sump joint and takes about 10 seconds to start running off the sump.
I can wipe my hand across the back of the engine and there is just dust so it's not the cam cover.
Any suggestions anyone?
Old 01-26-2016 | 07:58 AM
firebirdparts's Avatar
Possibly a cam seal. If so, you may find the seal has "walked" out of the engine.
Old 01-26-2016 | 08:09 AM
mpe's Avatar
mpe
Thanks for the reply - is it possible that the belts would not show any signs of oil on them?
Everything under the belt covers is very dry - not a sign of oil.
The oil does take 10 -20 seconds before it starts to run off the bottom of the engine, so I was thinking it may be coming from somewhere near the top.
Old 01-27-2016 | 04:09 PM
the two big leak items are the cam seals (front and rear) and the turbo oil return line (that can make such a huge mess for such a small part). The squeal on start up sounds like a belt noise or an idler on its way out. Best to check that the timing belt and serpentine belt have not picked up any oil.
Old 01-28-2016 | 03:54 AM
mpe's Avatar
mpe
Default Cam seals
Thanks, looks as though the cam seals are the first thing to check (non-turbo) and a timing belt is due for replacement anyway.
I had expected to see oil sprayed on the belts but they at dry with no sign of oil.
Are the front cam seals difficult to replace?
Old 01-28-2016 | 02:01 PM
No. Easy and cheap.
Andrew Fritz
01-10-2016 06:44 PM
broken08
1998-2000 model year V70
10-11-2015 08:37 PM
FernBchJeep
05-26-2013 08:47 PM
racefan18
10-31-2011 09:10 PM
Quick Reply: 2001 V70 BIG oil leak from front
