Big Leak
Old Sep 28, 2011 | 06:48 PM
racefan18's Avatar
Default Big Leak
i have had a consistant leak for a couple years. my old mechanic showed me two lines that run into the bottom of the rad? i think. located on the right front of car. can someone tell me what these two lines are. looks like oil, but car doesnt seem to use a lot. runs great, air is cold.
Old Sep 28, 2011 | 07:56 PM
Is your car turbo? Please give some more info on the car.
Old Sep 28, 2011 | 07:57 PM
Oil Cooler Line replacement instructions on a 1998 Volvo S70 GLT
Old Sep 28, 2011 | 08:40 PM
racefan18's Avatar
Sorry, 97 850 GLT 2.4l turbo.
Old Sep 29, 2011 | 09:15 PM
Vmax's Avatar
FCP, I got mine last week for $222 with the coupon code. You get OEM Volvo parts.
Good luck installing these in a short time, it was a nightmare for me and othermembers due to the layout and limited space to get to the bolt on the engine block at the front, and the bolt holding the lines to the block passenger side directly behind the subframe..
The bolt at the front was so impossible for me to get to thanks to the AC compressor bolt getting in the way, I just broke out my trusty bolt cutter, grabbed the old lines and started ripping up ****!
http://www.matthewsvolvosite.com/forums ... =1&t=33489
Seems like now's the time the lines get leaky on these cars..
Old Oct 31, 2011 | 09:10 PM
crotext's Avatar
I agree that this job is a pain in the butt. I have mine apart and still trying to get the lines back into the thermostat unit whiich is attached to the engine block. According to a parts source, the lower hose (right angle bend) attached to the radiator is the inlet and upper hose is the outlet.
I removed the thermostat housing from the block by using a long, sharp chisel since the Torqx part of the screw heads turned and stripped. I plan on replacing those with #7 metric cap screws. I could sure use a picture of how those hoses install to the thermostat side.
Currently I am trying to align the new, remanufactured hoses to reattach them and find that one will not seat as low as the other. I'll post more and maybe some pics if I ever get it done. I am thinking maybe this car is for sale soon.
FernBchJeep
May 26, 2013 08:47 PM
1998S70GLT
Apr 23, 2010 07:38 AM
rmmagow
Feb 28, 2006 12:02 AM
fignozzle
Nov 15, 2005 02:04 PM
dmoney
Aug 1, 2005 08:11 PM
