2001 V70, radiator fan won’t come on when AC is on.
Old Sep 28, 2020 | 06:12 PM
Abbotn's Avatar
Exclamation 2001 V70, radiator fan won’t come on when AC is on.
My brother gave me his V70 about a month ago. I just replaced the AC compressor, radiator and idler pulley.
This last weekend I finally got it back together and charged the AC and noticed the fan does not come on. The AC works, but no radiator fan, so I used a big electric fan I have to test the AC.
I do have 12v power at the connector at all times. So I’m looking a way to test if the fan is bad, or the control module, or if the signal to turn it on is not working.
Does anyone know what signal is supposed to be on the small gauge wire going to the control module?
Is there a way to override the cooling system to force the fan on?
Thanks in advance,
PS: The fan does not come on when the car reaches temperature either, but I wrote that off because its a new radiator and the days are cooler here in the northeast. Also, the car is not road worthy yet, so I can't give it a drive test.
Old Sep 28, 2020 | 07:39 PM
Originally Posted by Abbotn
Is there a way to override the cooling system to force the fan on?.
Yes you can plug into the car using VIDA and a dice unit, or an appropriate scan tool to manually turn on the fan.
darkblueS40
Nov 26, 2017 07:16 PM
sheli1014
Jun 4, 2014 12:00 PM
mathew05
Sep 1, 2011 09:11 AM
dpjnicholson
Nov 12, 2010 12:08 AM
740SkiWagon
May 16, 2008 05:08 PM
