2003 V70- noise under car when accelerating
Old Feb 21, 2016 | 10:50 PM
hockeyfool's Avatar
Default 2003 V70- noise under car when accelerating
We have a gradually louder noise happening when accelerating beyond the in park position, so when stepping on gas pedal you can hear it;louder in second gear but volume tapers off when in 4rth/drive to passing/highway speeds.
Its seems to be also a vibration that is under car in center area, maybe at catalytic converter ?
Not sure....heat shield , exhaust hanger broke ?
any ideas ?
Old Feb 22, 2016 | 10:12 AM
firebirdparts's Avatar
buzz? Rattle? Hum? Roar? Moan? Online car diagnosis is good for the vocabulary.
Old Feb 24, 2016 | 03:17 PM
hockeyfool's Avatar
the sound is variable with engine speed, but mostly like a buzz with a rattle , as it sounds like a loose part that is vibrating or shaking against another part, the hum or buzz like sound changes with a rattle sound then as car is at highway speed, it tapers off.
Old Mar 1, 2016 | 03:35 PM
u check the heat shields behind the turbo?
Old Mar 1, 2016 | 05:37 PM
hockeyfool's Avatar
oh mine is a non-turbo...but the local midas muffler guy guy I trust took it for a drive, put it on the lift, and had a second man step on gas pedal to seek the noise; it cam from inside catalytic converter, now I got to choose an aftermarket to be welded on, or some other alternative pipe work...?
Old Mar 1, 2016 | 06:12 PM
Here's the thing - the factory part is a single unit that includes the flex pipe and the cat. Its not cheap ($400) but the risk of welding in a replacement cat is that you may still wind up replacing the flex pipe soon enough (a common point of failure - more so than the cat). You will also want to consider replacing the O2 sensors while the pipe is out as well.
Reminiscence
Sep 27, 2020 10:02 AM
square965
Aug 23, 2011 12:22 PM
weston97glt
Jun 24, 2009 10:45 AM
nvmx
May 28, 2009 09:33 PM
qianchq
Dec 2, 2007 03:03 PM
