2005 V70 Dies on highway, needs to be retstarted
Old Nov 28, 2017 | 08:24 AM
cbwollam's Avatar
Default 2005 V70 Dies on highway, needs to be retstarted
Our V70 will start and run fine. After 15 or so minutes there is a loss of power and it will die even while applying fuel. This is regardless of speed (though I believe it happens most frequently after driving at highway speeds for a bit.) The car will restart but needs to sit for a moment. I find that sometimes it is possible to over supply it with fuel and get beyond the trouble. I have done all major maintenance on the vehicle including replacing the breather box, timing belt. Tried cleaning the air intake and had the CEM tested and reloaded. Codes include 0300, 0089, 0191, and 0190.
Any info is greatly appreciated
Old Nov 30, 2017 | 06:20 AM
bullwad's Avatar
cHANGE THE FUEL FILTER
Old Dec 2, 2017 | 06:57 AM
pierremcalpine's Avatar
New Fuel Pressure Regulator is my guess. Same thing happened to a friend of mine.
Old Jan 15, 2018 | 10:15 AM
higgy baby's Avatar
I know this thread is a little old- but I had this same issue with my 05 V70.
I took mine to an independent shop that works on Volvos- $1235!
They replaced a lot of stuff that was totally unnecessary...but their diagnosis was "bad PVC system".
They replaced -
pvc catch tube
pvc oil trap
oil cap
oil and filter
thermostat
manifold gaskets intake
air filter
wiper blades!!!
coolant
motor mount
cleaned intake combustion system
$587- parts
$648- labor.
Now they wanted to do the timing belt!... It only had about 2 years and 40k miles on it. But I said NO.
I doubt I go back there?
Edit: But that did fix the problem..... they probably could have fixed it with a lot less expense though.
Old Jan 15, 2018 | 12:06 PM
tony1963's Avatar
Driving around a 13 year old Volvo with the original timing belt is not a good idea.
Old Jan 15, 2018 | 01:57 PM
higgy baby's Avatar
You misunderstood- Its not the original belt.
The belt that is on the car had only been there 2 years and has less that 40k miles on it.
Volvo recommends changing every 10 years or 105k miles- which ever comes first.
Old Jan 15, 2018 | 06:13 PM
sounds fuel pressure related - start by replacing the fuel pump relay (on the assumption its overheating losing its magnetism). If it works better with a new relay, start shoping for a new fuel pump as that may be drawing too much current for the relay, and then overheats as well. +1 on the fuel filter as a clogged filter can cause the pump to work too hard...
atsharp
Jun 3, 2016 03:52 PM
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
jayson44
Apr 11, 2013 01:52 PM
free1959
Sep 11, 2011 02:59 PM
mcadrenaline
Feb 15, 2009 11:31 PM
