adding roof rails
Old May 27, 2013 | 04:47 PM
mouseskowitz's Avatar
Default adding roof rails
I just picked up a '02 V70 and want to add roof rails. I seems that you have to cut off some of the molding to access the mounting points. What I'm trying to find out is if I can just go to the junk yard and pick up a set of rails or if I need to find a new set. Basically, can you reuse/easily replace mounting hardware or is a one and done deal for the rails?
Old May 28, 2013 | 08:37 AM
hovonogila's Avatar
You can reuse old rails and hardware. The aluminum roof inserts need to be removed and cut to fit....carefully. When I did mine, I "practiced" on the passenger side first. It came out fine, but I learned to be gentle cutting aluminum. Take your time and cut it slowly or bending and twisting will distort the surface. Be careful with the clips that hold the moulding in place. I reused mine, but I can see how they could be brittle and difficult to reuse. I pulled the moulding off the clips from the rear and left the front at the windshield still attached. Then I laid a blanket on the car to protect the finish. I "marked" the cut points with masking tape in order to get sections of moulding that fit between the screw-down plates in the roof. When I was done I had three little sections "left-over".
Old May 28, 2013 | 01:04 PM
I think I understand most of what you're saying, but I'm not sure what the aluminum plates that you're talking about are. Do you know of a tutorial or pictures I could take a look at?
hovonogila
May 16, 2019 02:28 AM
brooklynV70
Aug 24, 2011 10:48 AM
oldacura
Dec 14, 2008 07:35 AM
Old_Volvo_Fan
Nov 12, 2008 04:48 PM
Pretorien
Apr 28, 2006 12:34 AM
