EVAP hose mystery parts
Old Dec 24, 2018 | 08:28 PM
nli2va's Avatar
Default EVAP hose mystery parts
New to me 2004 V70 2.5T. So far quite happy with it. Taking my time around the engine and under the car to get familiar with everything.
EVAP Hose tree looks pretty old figured I'd replace them. Looking for P/N for two plastic clip/brackets on the front and driver side of engine block that tidies up the EVAP and Boost control hoses. Any ideas would be greatly appreciated.
I've gone through VIDA diagrams and parts diagrams on Volvopartswebstore and don't see anything remotely resembling these two pieces.
1st one at front corner, under Aluminium Crankcase breather tube. highlighted in green. In the middle is Turbo bypass hose. Part of EVAP hose tree is on the bottom, cracked and crumbling on the outside when I press on it. No codes yet, but probably not for much longer.
2nd part is on the side of the engine, sandwiched between the block and filter->turbo intake tube. it holds the EVAP Hose on top, and the 3 boost control hoses underneath. The top of it is broken off, looks like it's meant to be attached to the metal bracket on the left of the image.
Old Dec 27, 2018 | 07:28 PM
Georgeandkira's Avatar
I read your post on the other board. Glad you're making progress.
OhzKha
Aug 3, 2019 03:02 PM
Ronald's
Sep 16, 2018 10:16 AM
BPATR1CK
Jan 22, 2012 10:51 PM
skooter66
Jul 5, 2009 11:38 AM
92Typhoon
Apr 17, 2008 06:36 PM
