Help please...
Old Sep 8, 2014 | 06:15 PM
Ncsurfer's Avatar
Default Help please...
Have a 04 Volvo v70 2.4l non turbo, how do I get off intake manifold bolt just under thermostat housing? Any special tools?
Old Sep 10, 2014 | 07:40 PM
shoeboxOH's Avatar
I have a few pictures posted over at a thread doing exactly this. I ended up using several different length 1/4" extensions with an end piece that swiveled. You have to be a little bit crafty and definitely patient, but it will come off. I think I had to put the ratchet under the radiator hose and gingerly go about it that way. Also, that bolt will hit the thermostat housing when you are backing it out. It will thread out with just the smallest bit of force, at least mine did. I was worried that it would strip the threads, but if I recall correctly, there were only one or two threads left on teh bolt at that point.
Hope that helps. It is a tough one.
Here is the link I mentioned: https://volvoforums.com/forum/2001-2...lacment-73637/
Last edited by shoeboxOH; Sep 10, 2014 at 07:40 PM. Reason: updated with forum link
Old Sep 11, 2014 | 08:41 AM
Ncsurfer's Avatar
Thanks Shoebox for responding, that bolt was a doozy to come off, had to take off both thermostat housings to get to bolt, thanks again, Brian
mrlefler999
Mar 8, 2021 02:07 AM
MNWILD
Sep 10, 2020 11:29 AM
ericsb210
Mar 30, 2010 09:43 PM
Sanel30
Feb 18, 2010 09:16 PM
Epr7339
Jan 6, 2007 12:25 PM
